Sure, you can run without a computerif you swap to a carb, as long as it'snot an Auto TransWild
Will the ignition coil get the failsafe signal without an ECU? If not you could use a 413 dizzy and coil
Aren't 413s Samurais?
I'd say keep the Efi. You might want that rev limiter for mud
