Sidekick engine without computer?
  • 13 Replies
  • 5387 Views
Offline explosivo
  • 3157
« on: November 25, 2004, 12:04:30 PM »
Is there a not-too-complicated way to get a 1.6L 8v to run without a computer? Could I put a Samurai intake on it with an aftermarket carb that doesn't require a computer?
omghi2.us[/url]
Offline keith
  • 1176
Re: Sidekick engine without computer?
« Reply #1 on: November 25, 2004, 01:40:11 PM »
Why not just get a computer?  They are around $100 on ebay and from junk yards.
Offline explosivo
  • 3157
« Reply #2 on: November 25, 2004, 03:02:25 PM »
I have the computer... I want to ditch it on a forthcoming sidekick project that I'm planning (it's not for my beautiful black chop-job). :)
And for another question: in an 8v 5spd, does the computer control anything outside the engine? Is it tied into/controls the rest of the electrical systems, too, or what?
« Last Edit: November 25, 2004, 04:25:11 PM by explosivo »
omghi2.us[/url]
« Reply #3 on: November 25, 2004, 07:02:05 PM »
Sure, you can run without a computer
if you swap to a carb, as long as it's
not an Auto Trans
« Reply #4 on: November 25, 2004, 08:04:56 PM »
not an Auto Trans
Will the ignition coil get the failsafe signal without an ECU? If not you could use a 413 dizzy and coil
Offline explosivo
  • 3157
« Reply #5 on: November 25, 2004, 09:06:18 PM »
I was kinda wondering if the Samurai 1.3l distributor will bolt right up to the 1.6l head...
omghi2.us[/url]
« Reply #6 on: November 25, 2004, 10:49:22 PM »
I don't know what you get over there I was thinking of the electronic type without the ECU. My understanding is that it drops straight in. I need to confirm this though as I plan on replacing the points dizzy in my 410 (I know the 410 and 413 swap) for a 1.6 MPI dizzy
Offline explosivo
  • 3157
« Reply #7 on: November 26, 2004, 09:28:23 AM »
Aren't 413s Samurais?
I think it'd be less complicated for this project to just keep the computer and EFI.
omghi2.us[/url]
Offline bandit86
  • 1641
  • elv8rguy
« Reply #8 on: November 26, 2004, 01:28:13 PM »
I dont know what youre doing, but as far as wheeling, I'd never go carburated.  Maybe on a mudrun, where its full throttle all the way.
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #9 on: November 26, 2004, 02:10:44 PM »
I'd say keep the Efi. You might want that rev limiter for mud ;D
As we moving with the speed of the robot sonic exhaust
Chronic fumes, fuel, gin, and tonic
Half of the world is corrupt and alive
The other half is depressed and they want to die
« Reply #10 on: November 27, 2004, 07:15:30 AM »
Yes but there was also a 413 that wasn't a Sammi. It was an earlier version with the narrower track of the 410.
Crabzuki
« Reply #11 on: November 27, 2004, 07:25:49 AM »
not an Auto Trans
Watcha' talking bout, Willis? I have a dual set-up 40MM Carbs and it's an automatic transmmission. *NOTE* I'm not running any emission controls or computer.
Offline mrfuelish
  • 2862
« Reply #12 on: November 27, 2004, 08:07:41 AM »
yea, but does your auto have overdrive with a lock up converter?
« Reply #13 on: November 27, 2004, 09:15:21 AM »
Valve bounce has the same effect  ;D ;D
