Sidekick engine without computer?
  • 13 Replies
  • 5359 Views
Offline explosivo
  • 3157
« on: November 25, 2004, 12:04:30 PM »
Is there a not-too-complicated way to get a 1.6L 8v to run without a computer? Could I put a Samurai intake on it with an aftermarket carb that doesn't require a computer?
omghi2.us[/url]
Offline keith
  • 1176
Re: Sidekick engine without computer?
« Reply #1 on: November 25, 2004, 01:40:11 PM »
Why not just get a computer?  They are around $100 on ebay and from junk yards.
Offline explosivo
  • 3157
« Reply #2 on: November 25, 2004, 03:02:25 PM »
I have the computer... I want to ditch it on a forthcoming sidekick project that I'm planning (it's not for my beautiful black chop-job). :)
And for another question: in an 8v 5spd, does the computer control anything outside the engine? Is it tied into/controls the rest of the electrical systems, too, or what?
« Last Edit: November 25, 2004, 04:25:11 PM by explosivo »
omghi2.us[/url]
« Reply #3 on: November 25, 2004, 07:02:05 PM »
Sure, you can run without a computer
if you swap to a carb, as long as it's
not an Auto Trans
« Reply #4 on: November 25, 2004, 08:04:56 PM »
not an Auto Trans
Will the ignition coil get the failsafe signal without an ECU? If not you could use a 413 dizzy and coil
Offline explosivo
  • 3157
« Reply #5 on: November 25, 2004, 09:06:18 PM »
I was kinda wondering if the Samurai 1.3l distributor will bolt right up to the 1.6l head...
omghi2.us[/url]
« Reply #6 on: November 25, 2004, 10:49:22 PM »
I don't know what you get over there I was thinking of the electronic type without the ECU. My understanding is that it drops straight in. I need to confirm this though as I plan on replacing the points dizzy in my 410 (I know the 410 and 413 swap) for a 1.6 MPI dizzy
Offline explosivo
  • 3157
« Reply #7 on: November 26, 2004, 09:28:23 AM »
Aren't 413s Samurais?
I think it'd be less complicated for this project to just keep the computer and EFI.
omghi2.us[/url]
Offline bandit86
  • 1641
  • elv8rguy
« Reply #8 on: November 26, 2004, 01:28:13 PM »
I dont know what youre doing, but as far as wheeling, I'd never go carburated.  Maybe on a mudrun, where its full throttle all the way.
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #9 on: November 26, 2004, 02:10:44 PM »
I'd say keep the Efi. You might want that rev limiter for mud ;D
« Reply #10 on: November 27, 2004, 07:15:30 AM »
Yes but there was also a 413 that wasn't a Sammi. It was an earlier version with the narrower track of the 410.
Crabzuki
« Reply #11 on: November 27, 2004, 07:25:49 AM »
not an Auto Trans
Watcha' talking bout, Willis? I have a dual set-up 40MM Carbs and it's an automatic transmmission. *NOTE* I'm not running any emission controls or computer.
« Reply #12 on: November 27, 2004, 08:07:41 AM »
yea, but does your auto have overdrive with a lock up converter?
« Reply #13 on: November 27, 2004, 09:15:21 AM »
Valve bounce has the same effect  ;D ;D
