Snorkel
  • 18 Replies
  • 5900 Views
Offline takai
  • 907
Snorkel
« on: February 26, 2006, 04:41:52 PM »
Does anybody know of a company out there that makes a snorkel for the Samurai? I was hoping ARB did but, have been told no.  :-\  Anybody else know?
'Cause, I am to misbehave.
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
Re: Snorkel
« Reply #1 on: February 26, 2006, 05:11:48 PM »
Just for you. http://www.rocky-road.com/zuksnorkle.html
I pulled this from the article "Samurai snorkels are distributed exclusively thru Rocky Road Outfitters and imported direct from Australia. You will not find these snorkels for sale at any other Suzuki shop or ARB dealer."
« Last Edit: February 26, 2006, 05:15:17 PM by 97TRAKIN »
Offline locjaw
  • 2045
  • 22
Re: Snorkel
« Reply #2 on: February 27, 2006, 06:41:02 AM »
too bad the link says "temporarly out of production"(right under the price of $299.00 :o)
i'v seen ones made out of black abs, that actually look pretty good 8)
jason
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
Re: Snorkel
« Reply #3 on: February 27, 2006, 10:26:54 AM »
Or make one yourself, like i did ( just have to figure out an airfilterhouse off of which I can take the front when driving on the road)
Pipe is 3" exhaustpipe with Stainless 90 ° bends ( one of which was cut up to make the 2 short bends ). 3" because of the airvolume for the SuperCharger.
A friend of mine ( Mark ) works |removethispart|@ www.offroadcentre.nl and sells a snorkel for the Samurai, don't know the brand. Maybe you can contact him and ask.
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline takai
  • 907
Re: Snorkel
« Reply #4 on: February 27, 2006, 05:14:41 PM »
I could build one. I just haven't found a good way (i.e. decent looking) method to build the top part of the snorkel and set up a pre-filter. I thought about putting a K&N on the end and just using it as a pre-filter. Any other ideas?
Offline BigPig
  • 276
Re: Snorkel
« Reply #5 on: February 28, 2006, 12:31:02 AM »
I found an Aussie company that sells the top part/pre-filter that you can put on your own snorkel.  Try this http://www.uniflow.com.au/droopie.asp and see if it's what you want.
'89 Sidekick w/ 4.5" of lift.
Offline fRESH_OiL
  • 14
  • 98' Sport, Rocksteady
Re: Snorkel
« Reply #6 on: February 28, 2006, 08:58:16 AM »
I built one out of black ABS pipe... it is 3 inch, it isn't installed yet because I can't figure out how I want to do it just yet. But it looks nice and my favorite part is everything is from home depot, cheap and replacable. So if you roll, or crash, or whatever you can snap a new piece in with no cutting. Another reason I havn't installed it yet is because i can't decide if I should remake it with 2inch pipe... anyways.
peace
i'll post a pic when i'm done.
"El Duende" 98' Sidekick Sport JLX, OME Spring/Struts, DT Shocks, Warn Manual Hubs, 2" Body Lift, 16" EAlloy Wheels w/ 1.3" Spacers, 30" Wranglers. Next, ARB Lockers and Rhino Liner. And install that damn Snorkle I built.
Offline nitromax
  • 206
    • NitroMax's Pages
Re: Snorkel
« Reply #7 on: February 28, 2006, 11:49:04 AM »
I saw an ad for a "snorkel-hoodie" in an Aussie 4X4 mag, fits over the snorkelmouth. Mailed them for info and postage, never received an answer  >:(, might try the"droopie"-company.
Offline takai
  • 907
Re: Snorkel
« Reply #8 on: February 28, 2006, 03:38:43 PM »
It looks like they sell a pre-filter but, not the ram. That is the part I am really trying to find.  :-\
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Snorkel
« Reply #9 on: February 28, 2006, 04:22:18 PM »
The air ram can be bought directly from ARB.  It's a 3" diameter where it connects
888-4ARB-USA
1993 4-door Sidekick
4.24:1 t-case
Offline Jeff@TireBalls
  • 559
Re: Snorkel
« Reply #10 on: February 28, 2006, 06:01:38 PM »
I used PVC, I think it turned out great!
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Offline samuraiking87
  • PAVEMENT SUX!!!
Re: Snorkel
« Reply #11 on: February 28, 2006, 08:17:37 PM »
besides the snorkel tube what else do you have to do to make it submergable?
Offline fRESH_OiL
  • 14
Re: Snorkel
« Reply #12 on: February 28, 2006, 09:25:52 PM »
How did you attach it, what did you use at the top and at the bottom? Also, i've noticed many people turn the "ram" or intake to face the rear while other face it forward... whats your take on this?
Offline rockrat
  • 196
  • Got Ringr
Re: Snorkel
« Reply #13 on: February 28, 2006, 09:38:53 PM »
 cut and paste of the latest one we did
Ok for the snorkel step one, drill hole in cowel and mount snorkel
Step 2 route rubberized flex tub into engine compartment after a hole has been put through firewall, install Ace hardware S/S coupler to end of hose
Step 3 mount brackets to fender and pull S/S clamps through brackets
Step 4 install 3x4 modefied tube into air filter can and secure, then mount intake to Hose vis S/S Ace coupler
Step 5 take last pic dricnk more coffee
Oh ya get the right size S/S clamps for dry tank(moter tube)
Offline nitromax
  • 206
    • NitroMax's Pages
Re: Snorkel
« Reply #14 on: March 01, 2006, 12:24:51 AM »
I hopped from one board to another to find the same pics
