4 door front bumper mounting?
  • 17 Replies
  • 5184 Views
Offline chet
  • 556
  • Zuki time!
« on: February 04, 2005, 03:55:13 AM »
Ok I did a search and found info on mounting a bumper to a 2 door but looking at the front of my 4 door its totally different. Anyone got any pics or suggestions before I start on this?
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: 4 door front bumper mounting?
« Reply #1 on: February 04, 2005, 04:57:25 AM »
They're different???
Hmm, I have had the "bumper cover" off my 4-door, I guess, but I can't recall any differences.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #2 on: February 04, 2005, 05:01:25 AM »
the 4 door bumper bolts to the front of the crossmember between the lights.
as well as down by the front wheels.
Offline chet
  • 556
  • Zuki time!
« Reply #3 on: February 04, 2005, 05:35:59 AM »
here is a 2 door
and here is the best 4 door pic I could find
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #4 on: February 04, 2005, 05:47:10 AM »
Not sure what exactly you are looking for..
but on my 4 door the original front inner bumper, and the brackets for the calmini winch bumper mounted here:
With those lower brackets looking sort of like this (sorry, best pic I have)
« Last Edit: February 04, 2005, 05:48:47 AM by hcgalvin »
Heather Galvin
mudfkr
« Reply #5 on: February 04, 2005, 06:03:42 AM »
Hmmm totaly different, wonder why ?
heres the factory 3 door mounts, two 8mm bolts each side.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #6 on: February 04, 2005, 06:14:46 AM »
That's funny!  "3 Door".  Is that what I would call a 2-door tin-top?  Or just a regular 2-Door?
Bob
mudfkr
« Reply #7 on: February 04, 2005, 06:20:53 AM »
OK for you BOB, it's a '93 factory 2 door tin top (with a factory bucket dash  ;D)
Technically it is a 3 door really.....
Offline chet
  • 556
  • Zuki time!
« Reply #8 on: February 04, 2005, 06:59:03 AM »
So the Calmini bumper bolts to the factory 4 holes!  :o :o
Those are some pretty tiny bolts to be winching against!
I am building a bumper to hold my winch and was looking for something more stout than factory. Those bolts are fine for a thin stock bumper in a collision but when winching its not what I would call confidence inspiring.
mudfkr
« Reply #9 on: February 04, 2005, 07:12:36 AM »
If your doing a custom bumper I'd be cutting the front body mount off the frame then cutting some 3/8 or 1/2" plate to the shape of the frame  and tapping some 3/8 bolt holes in it as bumper mounting points and welding it on and then weld the body mount back on top of it.
Kind similar to what I done in the pic above but with the 2 door I had to work to the inside of the frame.
Offline chet
  • 556
  • Zuki time!
« Reply #10 on: February 04, 2005, 07:41:39 AM »
now thats a hell of an idea! Thanks! I will be sure to post pics when done.
mudfkr
« Reply #11 on: February 04, 2005, 08:07:50 AM »
Chet,
Although mines a 2Dr have a look at my pix here http://pg.photos.yahoo.com/ph/mudfkrs/album?.dir=1ac4 it might give you some ideas before you start.
As you'll see it  started out with no winch, mounted a winch on it, then finally remounted it and got it to where I was finally happy with it.
HTH Mud
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #12 on: February 04, 2005, 08:57:15 PM »
It's not a 2 dr 4dr thing it is a early model / late model thing.   My 94 4dr has the later style mounts.
I've got a 2 dr with the late mounts (Narrow) and a 4 dr with the early mounts (Wide)..    And I've got a 1998 with one of Each...  Bought crashed and lacked a good spare late model mount.
« Reply #13 on: February 05, 2005, 08:54:40 AM »
Its a pretty scary thought, I had my winch bumper custom made. New mountings are welded to the front of the chassis. Theres a total of 6 M12 bolts holding the bumper on.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #14 on: February 05, 2005, 09:44:44 AM »
Yeah, a lot of people weld the Calmini winch bumper mount brackets to the frame where they go.
Heather Galvin
