Need a good idea for a front bumper any pics..
  • 15 Replies
  • 5252 Views
Offline CJ11
  • 157
  • 95 SIDEKICK ON 31'S
« on: August 29, 2006, 08:17:59 PM »
Need some ideas for a bumper any would be good going to put a winch lets see what I get
Re: Need a good idea for a front bumper any pics..
« Reply #1 on: August 29, 2006, 09:45:19 PM »
Check out ShrockWorks. It Rocks. ;D
Offline kirknd4spd
  • 333
« Reply #2 on: August 30, 2006, 03:46:57 AM »
shrockworks, or calmini winch bumper
Offline Mike71
  • 1449
« Reply #3 on: August 30, 2006, 12:41:46 PM »
wish shrock had info about their tracker bumper on the website  :'( damn sammys get all the love
« Reply #4 on: August 30, 2006, 02:29:02 PM »
Do a sear ch for Shrock and you will find a pic of their bumper.
  • 6599
  • 68
« Reply #5 on: August 30, 2006, 03:52:30 PM »
We will be doing a full install / review on the Shrockworks Sidekick front winch bumper shortly, Stay tuned.
Here's a pic:
Offline Geared
  • 17
« Reply #6 on: August 30, 2006, 05:06:12 PM »
I like that bumper. But it will cost fortune a too get it over here in Norway :'(
88/90 mod Vitara 3dr hard-top.
1600 8v injection with Green filter.
3 inch suspension lift, 3 inch bodylift.
AVM locking hubs in front, Lockright rear locker.
33x12,5x15 Trxus mud tires.  My virutuell garage on www.offroad.no on this link: http://www.offroad.no/garage.asp?page=ShowID&ID=1563
Offline strvger
  • 95
  • Livin' on the edge... of the Great Northwoods !!
« Reply #7 on: August 30, 2006, 06:16:22 PM »
try:   www.ibuiltbumpers.com
he has a nice design in theworks for a trackick bumper that is very adaptable to just about anything you need.  i think he has a couple of pics of the protoype on the site.  if not, just email him or check out the pics at:  www.zuknation.net
good luck
'91 tracker, 1.6 8v 5-spd, 1.5 in susp lift,  DT header and 2 in exhaust, 235/75 AT's on 15x7 Turbines, 1st prototype: Ibuiltbumpers.com trackick front bumper!,  other mods coming soon!
Offline junkman
  • 73
  • Old stuff is OK
« Reply #8 on: August 31, 2006, 05:56:08 AM »
Here's a pic:
Eric,
Great picture! I hope mine will sit up and beg like that someday!
Junkman
One man's junk is parts for another man's 'kick!
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #9 on: August 31, 2006, 07:57:56 AM »
Check out ibuiltbumpers.com they just started doing bumpers for trackers/kicks.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #10 on: August 31, 2006, 03:36:48 PM »
i couldn't find anything about it other than it says they're going to start making them.   That's what everyone one says...
1993 4-door Sidekick
4.24:1 t-case
Offline strvger
  • 95
« Reply #11 on: August 31, 2006, 05:03:31 PM »
go to:  zuknation.net
then go to "forums" and scroll down to their 'Sponsers'.
  ibuilt    has pics there of the prototype.  it does have some custom features on it that may or may not be what you want, but he will work with you for sure.
Offline crikeymike
  • 713
« Reply #12 on: September 05, 2006, 03:33:37 PM »
I love it how toyota and suzuki are always mated together by small shops.  They build it for toyota first, then suzuki.
There are getting to be a few options now out for the front of sidekicks, but still nothing decent for the rear.
4.24:1 t-case
Offline strvger
  • 95
« Reply #13 on: September 05, 2006, 06:01:01 PM »
you're right about the rear.  after pulling the plastic off, the rear bumper doesn't look too bad on it's own.  i painted it good, then added a rather unique hitch/recovery point with welded reinforcement between the aftermarket hitch and the gas tank safety bar.  looks pretty good and very practical for my purposes.  i'll try to get some pics taken this weekend and post them here.  will have the new    trackick front bumper on by then too.  pics of that will be here too.
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #14 on: September 05, 2006, 06:57:24 PM »
Here's my bumper. It has 2"x4" x1/4" wall tube welded across the frame rails. Then I welded angle iron to the front of that for the mounts. On the back side of the bumper is the matching angle iron. There are holes in both pieces of angle to bolt the bumper on. The bumper itself is made of 10 gauge mild steel. It has 3 bends along the front face to match the curves of the front of the tracker and a top and bottom lip. It first started out as a steel step and had the top and bottom lips bent on it. I just notched the areas I wanted to bend and clamped it to a work bench and bent it by hand and welded it. It's very strong and not to heavy. Eventually I plan to mount a winch to the rail between the frame rails, this will sit behind the bumper and at that point I will cut a hole for the cable to come through. I will also mount some heavy plate to the rail and have it protrude through slotts in the bumper for recovery points. I made an identical one for my friends sidekick and welded the mount on and what not, so now they match.
 Try to build your own if you can, it's good fun.
