there is an arb air locker for the xl7!
  • 4545 Views
Offline Superzuki
  • 8
  • 2003 XL-7
« on: December 22, 2006, 09:40:38 PM »
the application chart on arb's site says
"Grand Vitara/XL7 (to 2005) front requires conversion using RD88, Vitara/Sidekick third member assembly and free wheeling hubs."
"Grand Vitara/XL7 (to 2005) rear requires conversion using Vitara/Sidekick third member assembly (and 26 spl axle shafts if required
No application for current model (2005 on) Grand Vitara."
has anyone installed one of these?
2003 XL.7
Yakima Loadwarrior on Suzuki crossbars
Calmini 2.5" lift with OME Springs and Front struts
235/70/16 Yokohama Geolander AT+II's
Offline blacknight
  • 987
    • Gonzookin
Re: there is an arb air locker for the xl7!
« Reply #1 on: December 24, 2006, 01:39:28 PM »
I hate to tell you this but you can"t bolt a Sidekick 3rd in place of a xl-7 one.  A GV  will work but the xl-7 isa  much bigger 3rd.
George
« Last Edit: December 26, 2006, 09:56:21 AM by blacknight »
Offline Superzuki
  • 8
  • 2003 XL-7
« Reply #2 on: December 24, 2006, 07:09:02 PM »
Pwned.
Maybe you should tell that to ARB George.  ;)
2003 XL.7
Offline blacknight
  • 987
    • Gonzookin
« Reply #3 on: December 25, 2006, 12:46:53 PM »
not unless the arb will fit and you just need to down grade to 26 spline axle shaft ???
Offline mckellyb
  • 31
« Reply #4 on: January 21, 2007, 07:57:41 PM »
Trust me, do not, under any circumstances, move down in size and durability to a GV pumpkin/third member.  I am at 75K miles, and have broken the pinion gear for the third time.  No abuse, minimal off-roading, and I even went farther on the 'Kick 5.12 diff than the second GV diff.  OEM diff, 55K miles, second GV diff, 5K miles, third 'Kick diff, 15K miles.  At least I know what the noise of diff failure sounds like when it's about 100 miles from detonation.
Right now, I'm not far away from slapping an XL-7, automatic trans, entire rear axle under there.  I'm tired of this part breaking...
'99 GV JLX+,manual front hubs,F&R 5.12 'Kick diffs,KYB's all around, tube & fin A/C condenser which shames the OEM one,Jeep TJ spring spacers on rear coils,225/75/16 BFG AT's, Yellow Box,missing lower half of the airbox (sound reasons),set up to tow behind a big diesel motorhome...XL rear axle soon?
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: February 04, 2007, 08:03:54 PM »
I bet ARB is talking about the front not the rear.
