Looking for pics of aftermarket tire sizes with stock height.
  • 17 Replies
  • 5437 Views
I'm trying to decide whether to lift my 03 Tracker or not, and wondering what it would look like at stock height with different tire sizes.  I was looking for pictures of stock trackers/vitara's with aftermarket tires/wheels.  Let me know what size your running with the picture.
-Thanks
-Dan
2003 chevy tracker (2.0L-auto-2 door-soft top)
MODS SO FAR....
-235/75/15 w/cragar soft 8's
-painted grill/graphics removed
-bull bar + off road lights
-Jeff's 2" spacer lift w/new rear shocks
-flowtech muffler
-Pacer Fender Flares
Offline bzzr2
  • 1011
Re: Looking for pics of aftermarket tire sizes with stock height.
« Reply #1 on: May 12, 2009, 01:19:47 PM »
see the 1st thread in this section, full of 2nd gen trucks and what's done to them
09 taco reg cab short box 4x4
Offline 1GV
  • 52
« Reply #2 on: May 12, 2009, 06:55:22 PM »
front stock height with 225/75/16, slight rub on plastic but fixed by bending one metal tab with my fingers to a 45% angle.
rear 40mm lift with no touching.
now 3inch front and 4 inch rear with the same tires  >:D
« Reply #3 on: May 12, 2009, 07:11:15 PM »
Thats a sweet ride.  Those pics are really helpful too.  Thanks for sharing.
-Dan
MODS SO FAR....
-flowtech muffler
Offline Toy Box
  • 222
  • 00 Grand Vitara
« Reply #4 on: May 12, 2009, 07:47:43 PM »
What did you do fora lift
You Play you Pay
Offline 1GV
  • 52
« Reply #5 on: May 12, 2009, 08:00:35 PM »
no worries dan, i love pics mine and others :laugh:
for a lift - 3inch struts, 3inch coils ( front/back ) , Extreme shocks, diff drops ( front ) , panhard spacer ( rear) and a 25mm coil spacer in the rear. Done  >:D
225/75/16 is a nice size but now thats it lifted im looking at 235/85/16s with a little trimming.
« Reply #6 on: May 12, 2009, 10:44:55 PM »
235/75/15 no lift, runningboards removed.
Front, same tires, No lift / Jeff's lift 1.5" front 2" rear
Back
My daughter wanted the running boards back
Before the lift it would rub in the rear just a bit loaded down and towing my 16' ski boat or the snowmobiles. It still rubs in the front if I turn it too far, but I never need to turn that sharp anyway, so it doesn't bother me at all.
« Last Edit: May 12, 2009, 10:52:13 PM by BackWoodsTracker »
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Offline revolved05
  • 29
« Reply #7 on: May 13, 2009, 04:46:35 AM »
ahhhhh nice proof of 235/75/15 will work before i do a coil spacer lift woo hoo for tires first haha.
01 tracker lt,bone stock... for now...
Offline bzzr2
  • 1011
« Reply #8 on: May 13, 2009, 05:31:14 AM »
just be sure that all you want is those tires... cause after you lift it and make room for bigger ones you might realize you wasted your money on small tires...  think about what you want and do it once!  might take longer to get done but will save in the long run..  enjoy.
« Reply #9 on: May 13, 2009, 01:07:14 PM »
Thanks for the pics, they are incredibly helpful.  I'm really torn about tire size.  I think I'm definately going with the 1.5/2" coil spacer lift.  Perhaps I'll lift it first then decide on my tire size.  I secretly want to go to 31" tires but I'm afraid that will rob my 4cyl (127 hp) automatic tranny 03 Tracker of all gas mileage/power?
-Dan
MODS SO FAR....
-flowtech muffler
Offline TopHeavy96
  • 488
« Reply #10 on: May 13, 2009, 03:46:17 PM »
Hey,  just for the heads up,  I'm running 30x9.5 m/ts on stock gears with the dinky little 1.6.  I did notice the drop in acceleration and mpg but not too bad.  The biggest problem I have is keeping the trans from trying to downshift out of overdrive on the freeway.  I'm thinking your larger engine might make up for the difference better.  I say lift it, you'll end up wanting to later anyway. ::)
Offline 1GV
  • 52
« Reply #11 on: May 13, 2009, 04:35:37 PM »
yes lift it but keep in mind you might want to make it higher again down the track.
i have a 4 inch lift and im now thinking i need more  ::)
Offline TopHeavy96
  • 488
« Reply #12 on: May 13, 2009, 05:00:41 PM »
That's funny,  I just got my lift and 30s and I already want bigger tires. I'm gonna have to go yota axles, with 33s i think.  Then those won't be enough!  ;D
Offline bzzr2
  • 1011
« Reply #13 on: May 14, 2009, 06:48:08 AM »
i ran 31x9.5 swampers for a couple years, they were lighter being thinner and worked very very well, when i switched to the ssr's which are 10lbs heavier per tire i noticed the extra weight..  maybe consider a narrower tire to save a bit of mileage.  then of course you could regear if that hasn't been mentioned... i never have yet because i'm still under manufacturers warranty until the end of this season..
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #14 on: May 14, 2009, 06:59:30 PM »
Agreed.  If you haven't bought your tires yet, then don't go rushing out to purchase the 235/75/15s.  Give it some more thought.  If you are running an auto tranny with the V6 you should be able to pull the 30/9.50/15 tires easily and with minimal rub.  Unless you are made of money, and some people may be, it's damned hard to justify buying a new set of "taller" tires if you just put 5000Ks/miles on the set that you just bought last month.  Avoid the "buyers regret".
Think hard about what the end state for the appearance, function (whatever) you want for your truck  before you jump.  IF you intend to put coil spacers or longer springs under your truck, then wait for the tires until you have the suspension lift completed.  THEN make your decision on your tires.  235/75/15s will fit without a lift, but you might have a little more difficulty fitting 30's under your truck without the lift.
I have a little bit of buyers remorse.... but I'm not buying any new treads until the ones I am rolling on now  are smoked OR unless I find a decent set someone has up for trade.  Personally, if I "had it all to do over again" I'd be riding on 30/9.50/15s now instead of 29" tires just for the slight additional clearance the tire height would add to my frame and body for plowing through snow and clearing the ground on trails.
The more snow you can roll over... the less snow you end up pushing.  The rear diff pretty much slides through the snow, but the frame and body just plows it and paclks it into the frame until you can't push anymore and then you eventually bottom out on what you tried to drive over/thru.  I hate that!!!
« Last Edit: May 15, 2009, 08:06:52 AM by nprecon »
