16 valve valve lash
  • 16 Replies
  • 5121 Views
Offline jawman
  • 406
  • 1234
16 valve valve lash
« on: October 09, 2010, 12:13:50 PM »
 I have done this on an 8 valve, but not on a 16valve. I can set the lash on the exhaust valves, but where do I put the gauge on the intake valves?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline gearjam
  • 97
  • RC 2010
Re: 16 valve valve lash
« Reply #1 on: October 09, 2010, 12:30:10 PM »
Between the cam and rocker. Thats how you should set them all.
Offline jawman
  • 406
  • 1234
« Reply #2 on: October 09, 2010, 06:10:38 PM »
on all the rest of them I was told to check gap between valve stem and adjuster.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
« Reply #3 on: October 09, 2010, 08:09:52 PM »
Any way you wish, just as long as the valve has the right lash,
otherwise you will burn the valves
« Reply #4 on: October 10, 2010, 06:28:55 AM »
On 8Vs, you check them between the rocker and valve stem.
On 16Vs, you check them between the rocker and the cam lobe.
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #5 on: October 10, 2010, 07:42:42 AM »
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #6 on: October 11, 2010, 10:29:53 AM »
Alternatively, you can just pluck all your valve-lashes...
 >:D
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #7 on: October 11, 2010, 12:18:47 PM »
LOL, good thing I wasn't drinking anything
Offline jawman
  • 406
  • 1234
« Reply #8 on: October 11, 2010, 05:13:15 PM »
thanks for the info. On another note I also noticed that the head set came with a flat thermostat gasket and not the O ring. To me it looks like I need the O ring type gasket and not the flat one. Is this correct?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline ranger88den
  • 279
« Reply #9 on: October 14, 2010, 06:06:59 AM »
I believe if the block or thermostat housing is machined with a shoulder (recess) the o-ring is required, if not then use the flat gasket, but not both.
« Reply #10 on: October 14, 2010, 06:25:51 AM »
Yep.  I have heard the same thing.
Offline jawman
  • 406
  • 1234
« Reply #11 on: October 14, 2010, 08:09:33 AM »
I need to find the oring then, but nobody seems to have one.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline ranger88den
  • 279
« Reply #12 on: October 14, 2010, 08:27:10 AM »
The last one I got was from NAPA but it was a while back and don't have a part number.
« Reply #13 on: October 14, 2010, 08:39:12 AM »
Hit the bulk bins of O-rings and match one to the Dia and thickness you need
Offline ranger88den
  • 279
« Reply #14 on: October 14, 2010, 09:20:31 AM »
If I remember correctly, the O-ring inner circumference is split so it fits around the outer circumfeence of the thermostat.
