Legality of driving on road without doors
  • 32 Replies
  • 8786 Views
Offline keith
  • 1176
« on: March 05, 2004, 12:41:53 AM »
Are there any laws regarding driving on road without doors?  Also how hard is it to remove and reinstall the doors on a Trackick?
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Legality of driving on road without doors
« Reply #1 on: March 05, 2004, 02:56:11 AM »
Varies by location.  Colorado has very loose laws - it's common to see topless, doorless rigs in the summer, all over the state.  I believe a BIG phillips screwdriver will remove the doors on a Kick (except mine, where the previous owner WELDED the hinge).
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #2 on: March 05, 2004, 03:09:03 AM »
He must of had his doors blown off too many times by a samurai  ;D    You could just fab up a quick bar going across, just so it looks like something is there, a friend of mine took a welding class at the local college and made a door that kinda looks like a v that hooks to the hinges and has a pin that drops throught the loop on the back, it's made of alum. so it is real lite and looks good 8)
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #3 on: March 05, 2004, 03:15:08 AM »
He must of had his doors sucked off too many times by a samurai  ;D
What you MEANT to say...   ;)
Bob
lucszuk
« Reply #4 on: March 05, 2004, 04:12:54 AM »
ive never been stopped i but im in canada so i dont know
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
« Reply #5 on: March 05, 2004, 04:41:08 AM »
Here in Florida having doors on or off is a variable dependent on your floor-sill.
Samurais and most Jeeps/Trucks have enough of a sill below the door such that if something falls on the floor, it will not be able to roll out of the vehicle. After talking to a local (florida again) police officer, he said the only concern about people running doorless is things rolling out of the vehicle at speeds and causing injury, accident, or otherwise. As said, the sills prevent this.
'87 TinTop
'04 F-150
Offline Ronzuki
  • 261
  • What's a Samurai?
« Reply #6 on: March 05, 2004, 06:55:53 AM »
That's interesting info, I would never have thoght that to be the reason,but makes good sense.  ;)
'91, RRO Bolt-On SPO, 32" BFG Muds, 2" BS U.S. Wheels, Breeeze CO, Neon Seats, 5.8:1 T-Case, TT Mighty Kong Bucket, 1.5" RUF, 1.5" Rears, DT Shocks, RRO Sliders ,Rear DetroitEZ, OBA,Celica PS
RCrocs Team 509
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #7 on: March 05, 2004, 07:23:38 AM »
In Michigan I ran all last summer with my doors off.  Never had a problem.
32 MTR's Warn 8000i
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #8 on: March 05, 2004, 02:50:36 PM »
I also run with the doors off alot in the summer. Ive had no problems so far... Except rain! :P
Mike
Offline explosivo
  • 3157
« Reply #9 on: March 06, 2004, 12:39:38 PM »
as far as removing the doors, it's as simple as taking off the fenders and removing 4 bolts.
omghi2.us[/url]
Offline keith
  • 1176
« Reply #10 on: March 06, 2004, 01:43:33 PM »
How simple is removing the fenders?
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #11 on: March 06, 2004, 02:02:05 PM »
I just open my doors and pull the pins.  Then I filed down the barbs that keep the pin from spining when you use the doors.
I keep them oiled so wear is not a problem.
So now when I want the doors off.  I pull four pins and off I go.
When I'm done, I just put the pins back in.  No lining up the doors.  Had no problems so far.
32 MTR's Warn 8000i
Offline jagular7
  • 1026
  • Jagular7
« Reply #12 on: March 06, 2004, 02:20:53 PM »
Could you provide a close-up picture. I'm confused.....
Lenexa, KS
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #13 on: March 06, 2004, 09:25:42 PM »
Have you ever taken a door off in your house by pulling the pins out of the hinges?
Anyway, no I don't have any pictures at this time.  But just open up your doors, and look at the hinges.  Down through the center you will see a steel rod going from the top to the bottom of the hinge.
The top hinge, the pin is installed from the bottom.  If you look you will see it's pointed at the top and a "E" clip holding it in place.
Remove the clip and drive the pin down and out.
Same for the bottom but you have to drive the pin up.
32 MTR's Warn 8000i
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #14 on: March 07, 2004, 02:10:56 AM »
I know that doors and side mirrors are an option in NC. Don't even need them to get inspected  ;D
« Last Edit: March 07, 2004, 02:18:09 AM by nc_zuk »
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
